How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
What could be the reason for the idling vibration in a Nissan Sunny manual transmission? I've replaced the spark plugs, but it hasn't solved the issue.
How can it be called a 2018 model if it hasn't been released yet?
4Navara 2019 model, currently has over 60,000 kilometers. When changing the spark plugs, there was oil in the cylinders. The 4S technician said the valve cover needs to be replaced due to internal leakage and should be replaced together. I want to ask everyone, is this a common issue with the Navara?
5Why hasn't it been updated yet? It's still the 2021 model.
6Hey guys, at how many kilometers did you change your spark plugs? 😎
7The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
8Do I need to change the transmission oil for a 2019 GAC GS5 Elite version with 70,000 kilometers on it?
9Why hasn't the RX5 Max been marked as discontinued yet?
10How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
