Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
Taycan owners, I have a question about a feature. As you might know, in the Taycan's triple display, the middle one shows the speed by default, and when the power meter is checked, it shows acceleration and energy recovery levels—blue for acceleration and green for recovery. In my car, with the default set to normal mode, when I press the accelerator, the blue bar shows up normally. However, when I press the brake, the green bar doesn't show at all, although the car brakes fine. Does this mean my braking relies solely on mechanical brakes without energy recovery? Is there a way to set it so the green bar shows normally when braking? I'm sincerely asking for advice, thanks everyone!
When I don't press the accelerator, the speed gradually drops to 0. What's going on?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
4Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
5Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
6For a 10-year-old black Jetta, when lightly pressing the brake, the ABS engages, and at around 10 mph, the ABS starts working. What have others replaced to solve this issue? [facepalm]
7Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
8I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
9My car is a 2.0 naturally aspirated engine. When I gradually accelerate past 80 km/h, the car shakes a few times, and then it stops shaking. However, if I press the accelerator hard, this doesn't happen. I wonder what's causing this.
10Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
