Hey guys, does anyone know if a bad bearing on the right front wheel of the 2019 GS5 270T Automatic Deluxe model would trigger fault codes for the whole car? Also, there's a strange noise when driving on bumpy roads. Thanks!
Has anyone replaced the central control system on cars after August 2019? If you removed the original system, did it trigger an engine fault code? How did you resolve it?
I have a 2019 GS5, and since early August, there's been a buzzing noise when driving between 60-100 km/h. It feels like I'm flying a plane, especially when I turn right, it gets louder. The dealership said it was a wheel bearing issue, so I had the bearings replaced, then the tires, and even the half shaft, but the problem still isn't solved. Has anyone else had this kind of issue? Please point me in the right direction. I don't want to keep wasting money and time on blind repairs. [About to cry]
Hey everyone, the chassis of the GV80 feels too stiff, and the ride comfort is really poor and bumpy. The roads I'm driving on aren't even that bad. It seems like having no air suspension is really an issue. Any suggestions?
4The check engine light on my Nissan Sunny came on, showing fault code P0705-00, which indicates an issue with the transmission range sensor A. The car suddenly jerked, and then the gear indicator on the dashboard disappeared. After turning off the engine and restarting, the gear indicator reappeared, but after a while, the check engine light came on again. I went to a repair shop to clear the fault code, and it seemed fine while driving, but the issue occurred again after some time. This has happened several times. Could it be a problem with the right tail light base?
5Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
6Hey guys, does anyone know if a bad bearing on the right front wheel of the 2019 GS5 270T Automatic Deluxe model would trigger fault codes for the whole car? Also, there's a strange noise when driving on bumpy roads. Thanks!
7I have a 2018 Haval H2 manual with a red badge. The ABS light is on, the central console reports an auto hold fault, a hill descent fault, and the steering wheel feels heavy as if it's lost power assist. Previously, a repair shop read the fault codes and showed a right rear wheel ABS fault. I replaced both rear wheel ABS sensors, but the issue persists, and now there's a new problem. Before, I could turn off the engine by pressing the start button once. Now, it doesn't turn off with one press; I have to press the brake and long-press the start button to force it to shut down. Does anyone know what's going on? I'm really fed up with this car. After this experience, I don't want to buy a GWM car again.
8Does this car have good off-road capabilities, suitable for road trips? The back seat seems really spacious, good for sleeping, right? I'm not too worried about fuel consumption since it's American, as long as it's not too bad. I'm just concerned that besides being big, it won't be like a car costing around a hundred thousand [facepalm][facepalm] How's the driving experience and all that?
9For a 2020 GS5 with over 30,000 kilometers, experiencing continuous jerking when lightly pressing the accelerator at speeds above 100 km/h, but not when pressing slightly deeper, and with no fault codes, what could be the issue?
10After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
