أحمد بدر الدين
2023-10-19 15:04
Hello, car enthusiasts group. When swapping the positions of all four tires, is it necessary to do wheel balancing and alignment?
سلمان رامز
سلمان رامز2023-10-23 09:25
There's no need, but after swapping positions, the tire pressure display changes.
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
Can the Acura MDX have a four-wheel alignment done?
Is it necessary to do wheel alignment after picking up the car? I did some research and found that issues with the camber angle can lead to inner tire wear. Not sure if the new model has this problem?
Looking for four original wheels and tires 235/45 R17, the newer the better. Just the four wheels alone are also fine.
Hey fellow car enthusiasts, I swapped to AT tires before, but they're too noisy on the highway. Any recommendations for a quieter tire brand?
I accidentally hit the curb with my left rear wheel and the tire got damaged. During the four-wheel alignment, they said it couldn't be fully adjusted. If the tire is damaged, does it really require changing the shock absorber? Is it really that serious?
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
GAC GAC GS5
GAC GS5TBDGasoline
