خالد أرسلان
2024-04-19 18:34
For the 2019 GS5270T model, if the vehicle randomly triggers an alarm as if someone is trying to open the door without a key, but no one actually does, and it happens multiple times a day, how can this be resolved?
عبدالله عَبْدُ الْعَزِيز
عبدالله عَبْدُ الْعَزِيز2024-05-07 15:16
It might be that you need to change the key battery. After changing the key battery, try starting the vehicle. I had a similar issue some time ago, and after starting the vehicle, everything worked fine.
عبد العزيز فاتح
عبد العزيز فاتح2024-04-24 13:28
My car alarm went off twice, starting about fifteen minutes after locking the car. Do you have anything plugged into the OBD port? If not, check if there's any other equipment causing interference. The dealership said there's a problem with the car lock alarm module.
نايف سهيل
نايف سهيل2024-04-20 02:52
Check if the door switch contact is damaged. If not, see if there are any signs of mice.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
Haven't driven my car for a few days. Almost fell asleep when my neighbor messaged me saying my car's hazard lights were flashing. Went downstairs and sure enough, they were. No alarm, just the hazard lights. Couldn't turn it off with the key, so I had to get in, start the car, and turn off the hazard lights to stop it. Really bizarre.
I am looking to buy a 2.7 model with a hood from 2018 to 2023, or the new Haval H9, without any basic options. Could someone help me analyze this? I actually want to buy a Prado 3.5, but it's inconvenient to get 95-octane fuel in my area. Thanks for your input!
When the air conditioning is turned on in the 3008, it triggers an alarm, but it goes back to normal when the AC is turned off. What could be the problem and how can it be resolved?
Is it advisable to buy a 2019 Ford Territory with the highest trim level if it keeps triggering the alarm automatically all day until the battery is drained?
The car hasn't been driven for just two days, and the door can't be unlocked. I used the mechanical key to open the door, but there's no power at all inside. What's going on?
There's a bug in the fuel consumption mileage stats of the Nissan X-Trail EP, which causes it to reset automatically. This has happened a few times, and each time all the data on the "Since Last Refuel" page gets cleared. I'm not sure if it's a bug. It's still hard to pinpoint the exact conditions for the issue to reoccur, but I can confirm it should include the following: 1. Long periods of idling without turning off the engine 2. Unlocking the car doors 3. Leaving the car with the key (out of sensing range) Then, when you return, you'll find the data has reset. This has happened three times, and looking back, it was pretty much under these circumstances.
Fellow car enthusiasts, have any of you experienced this situation where the transmission control system malfunctions, the power can't be turned off, the key fob lock button stops working, and then everything returns to normal after about half an hour to an hour? It's a three-month-old car, and this issue has occurred multiple times. I've been to after-sales service, but it hasn't been resolved.
If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
GAC GAC GS5
GAC GS5TBDGasoline
