For a 2020 GS5 with over 30,000 kilometers, experiencing continuous jerking when lightly pressing the accelerator at speeds above 100 km/h, but not when pressing slightly deeper, and with no fault codes, what could be the issue?
When lightly pressing the brakes on the Vellfire, there's a slight "click" sound. Has anyone else experienced this?
Fault code P0504, currently gears 1, 2, 3 are fine, but when switching to 4th gear, the car loses power when pressing the accelerator and doesn't accelerate. The RPM drops very slowly when pressing the clutch. Has anyone else experienced this?
What are the issues when the warning lights for these fault codes appear on a 2015 MG GT?
4When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
5When driving a Toyota Vellfire at speeds above 100 km/h, if you release the accelerator, the car tends to jerk repeatedly. Even after changing the engine oil and spark plugs, this issue persists.
6Hey guys, does anyone know if a bad bearing on the right front wheel of the 2019 GS5 270T Automatic Deluxe model would trigger fault codes for the whole car? Also, there's a strange noise when driving on bumpy roads. Thanks!
7What causes a jerking sensation when gently pressing the accelerator?
8For a 2020 GS5 with over 30,000 kilometers, experiencing continuous jerking when lightly pressing the accelerator at speeds above 100 km/h, but not when pressing slightly deeper, and with no fault codes, what could be the issue?
9What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
10When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
