عمر حكم
2024-01-09 22:18
Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
حازم محمد
حازم محمد2024-02-27 21:27
Aisin 6AT doesn't have an oil pan.
سلمان رامز
سلمان رامز2024-01-24 13:39
The cycle machine doesn't need to be dismantled, but removing the base cover for a thorough cleaning could pose an oil leakage risk.
Do I need to change the transmission oil for a 2016 Skoda Rapid, automatic, 6-speed?
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
Should I change the transmission oil for a 2019 GAC GS5 270 Premium Edition with 60,000 km?
Do I need to remove the oil pan to change the oil?
Does the 2019 model with 1.4T engine need a transmission oil change at 60,000 kilometers? Some say it's maintenance-free, while others say it needs to be changed. I'm not sure what to do. Have any of you changed it?
Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
Do I need to change the transmission oil for a 2019 GAC GS5 Elite version with 70,000 kilometers on it?
Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
GAC GAC GS5
GAC GS5TBDGasoline
