The 2019 GAC GS4 emits a beeping alarm sound when it exceeds 30 mph.
When the car's steering angle exceeds 100 degrees, the chassis sometimes makes a "ka-ka" sound. What's the issue? It happens occasionally.
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
Is there anyone who has experienced noise from the passenger side when turning on the air conditioning in the 2019 GAC GA6? How did you solve it?
4Why does the car beep three times when starting, like the sound when a door isn't closed properly?
5The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
6When the car is moving, there's a beeping sound. The seatbelt, fuel, and camera are all fine, and it's not the collision warning. Does anyone know what could be the reason?
7When driving the Kamiq, if a red "P" appears on the dashboard and there's a beeping sound similar to the seatbelt alert, what could be the issue? Can anyone advise? Thanks!!
8The 2019 GAC GS4 emits a beeping alarm sound when it exceeds 30 mph.
9How to set up the lock beep for the 2019 MG ZS Global Luxury Edition? The central control is already set to lights and beep, but when locking, only the hazard lights flash without the beep. Tried all the suggestions from Douyin and Baidu, but still can't get the lock beep to work.
10My car has keyless entry, but after unlocking, the car gives four alarm sounds. What's going on? This didn't happen before. It used to just unlock automatically when I got close, with the lights flashing but no sound. Now it flashes four times and gives four alarm sounds!
