Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
How can I make CarLife full screen on the 2021 Intelligent Technology Edition?
I have a 2019 GS5 Elite version. Sometimes the central control screen doesn't power on, but the air conditioning works fine. The reverse radar is not usable, and the central control screen doesn't light up. Does anyone know why this is happening or has anyone else encountered this issue?
Can the 2021 Tech Smart Edition have a one-touch window lift installed?
4When starting a cold car, it should normally take about 2 seconds, but sometimes it takes 5 or 6 seconds. Does anyone else have the same issue? Last time, I replaced a solenoid valve under warranty, but it didn't help. The warranty is about to expire, and I want to fix the problem. I have a 2019 GAC GA6 Luxury Edition.
5Does anyone experience the 1.3T 80th Anniversary Edition's central control screen occasionally freezing? It gets fixed by disconnecting the power and restarting.
6Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
7Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
8Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
92015 Red Label manual Xiao Er suddenly lost all power and the screen went black while driving, and it wouldn't start. After two or three minutes, it was fine again. Has any fellow car enthusiast experienced the same situation?
1021 Dark Special Edition, original paint, green, registered in October 2021. Comes with imported Rollypus invisible car film (worth around 30,000). Mileage is 17,000 kilometers, no off-road history, regularly maintained, excellent condition. How much can it sell for? The 21 version has the highest configuration, with a large screen, electric suction doors, and nothing has been downgraded.
