Is the GS4 MAX 2024 version suitable for women to drive? With a height of 155 cm, can the driver's seat be raised? It feels like the car door blocks a lot of the view.
There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
Does anyone know the interior space dimensions of the Iveco long wheelbase high roof model? 1. The distance from the back of the driver's seat to the rear of the van, 2. The interior width, 3. The interior height, 4. The door width.
Where can I adjust the height of the driver's seat in a 2010 Lancer?
4I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
5Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
6Can the rear seats be folded down? Where can I adjust the height of the driver's seat?
7Is there anyone here who bought the GS4 Max in 2024 and can share their experience? I just test drove it a few days ago and really liked it, but the online reviews aren't very positive. People are saying there are a lot of strange noises and minor issues, and that rust is a big problem. How does it compare to the Nissan Qashqai?
