سعود رياض
2024-12-01 23:55
Hey experts, when driving the GS417 model, it feels like being on a boat whenever the road is uneven. What could be causing this shaky, wobbly experience?
عبدالله لطيف
عبدالله لطيف2024-12-02 07:48
Please check the suspension structure of the vehicle's chassis.
What could be the reason for a 2015 car making squeaking sounds when driving on uneven roads?
Hey expert, could you please tell me how to use the Jimny's differential lock and where the switch is located?
What could cause a 2019 Toyota 4Runner to feel like the transmission is slightly vibrating or lacking lubrication when accelerating uphill?
Guys, many people are saying that the GV80 has issues with bumpy roads and uneven surfaces. Is this true? How can we go on road trips then? Could it be a problem with their mode settings or the electromagnetic suspension?
2017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
Is it normal for a manual 10-speed vehicle to feel very bumpy on slightly uneven roads?
Why does the 2016 308 1.2T automatic feel a bit shaky in higher gears? Could it be due to insufficient engine torque? Do fellow car enthusiasts experience the same issue?
Hey friends, when the car is running, it shakes. I did a front wheel balancing, but it still feels a bit shaky. What could be the reason?
The rear wheels feel like being on a boat, swaying side to side. What could be the issue?
When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
