Help needed! I have a 2017 GS4. When I start the car, the RPM goes straight to 2000, and the engine sounds like it's being revved. Even after waiting for more than ten seconds, it doesn't go down. But when I shift to D gear, the RPM returns to normal.
Is it normal for the RPM to increase by 100-200 when shifting the FJ from D to N, and then continue to maintain the increased RPM?
4Hey car enthusiasts, does your Eclipse Cross rev to 1500 RPM when in Park?
5Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
6Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
7When the car is not started, the brake works, but after starting, the brake pedal goes straight to the floor. What could be the issue?
8Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
9Hi everyone, can someone help me out? Today, I suddenly noticed a noticeable "da-da-da" sound from the engine when it goes above 2000 RPM. What could be the issue?
10What's the RPM for your manual transmission car at 120 km/h? Mine goes straight up to 3400 RPM! [Shocked]
