GAC GS4 has been used for 5 years without changing the brake fluid or coolant. The car has run less than 30,000 kilometers. Do I need to replace them during the next maintenance? Thanks, everyone.
The Viano has a power leakage issue. In less than a week, the battery is completely drained, even the remote control for the doors doesn't work. Still can't figure out the cause.
4Hey car enthusiasts, I got my T60 at the end of May 2017 and in less than a year, the car body has started rusting. Have any of you experienced this?
5Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
6Why does the 2022 Nissan Altima have a door noise issue? The car is brand new and has less than 1000 kilometers. Looking for advice from experts.
7The Jietu 90 has too many issues. At less than 20,000 kilometers, the one-touch start fails to work, and the 360 camera malfunctions, sometimes even resulting in a black screen.
8Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
9Recently, the engine start-stop system suddenly stopped working, and I didn't turn on the AC. It's been less than three years and under 30,000 kilometers. Does anyone know the reason?
10I got my Defender 110 less than 4 months ago, and the wipers are already leaving a lot of water streaks. Has anyone else experienced this? What brand of wipers did you switch to?
