حبيب محمد
2024-12-03 23:19
For the 2017 GAC GS4 with the 1.5T engine, are the front brake pads large or small? Could any fellow car enthusiasts help with this information?
عمر جعفر
عمر جعفر2024-12-04 02:55
Go ask the customer service on Taobao.
After changing the brake fluid in my GAC GS5, the brakes failed. I thought it might be an issue with the master cylinder, so I replaced it, but the problem still wasn't solved. Can any experts offer some help?
There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
When the steering of the 2017 Honda City is turned fully, there is a stuttering, as if it's stuck, but there is no issue with small turns. What could be the reason for this? Can anyone help with this? Thanks a lot.
Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
Hi everyone, I'm looking for advice from fellow Grand Cherokee owners. A braking distance of 43 meters seems pretty bad. Has anyone done any modifications? What brands did you use? Is it enough to just replace the brake discs, calipers, and pads? What's the braking distance after modification? Also, has anyone switched to LED headlights? How's the performance? Which brand did you go with?
When the vehicle just starts, there's a whistling sound from the front wheels, but it disappears after driving for a while. What's the reason? Could it be that a small stone got into the brake disc?
Hey guys, need some help! Has anyone experienced the car suddenly braking on its own? The dashboard shows braking, but there's nothing in front.
Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
