Does the 2022 GAC GS4 Smart Technology Edition 360 have an automatic pop-up function when turning on the turn signal?
How do I turn off the 360 panoramic image that pops up on the central control when turning?
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
I bought the 2022 GAC GA6 in May this year, and the remote key's automatic unlocking function when approaching the vehicle is gone. Does anyone know why?
4Is there anyone experienced with installing a 360-degree camera? Could you please tell me where to find the turn signal wire? I've been looking under the driver's side and can't find it. 🤣
5If you're deciding between the BYD e2 Honor Luxury Edition and the Dongfeng Nano O1,430max, both priced similarly, it comes down to what you prioritize. BYD might offer more brand prestige, while Dongfeng could provide more advanced smart features. Consider what matters more to you: brand value or technological enhancements.
6Regarding the issue where the 360-degree camera system doesn't activate when reversing, but works fine when the turn signal is on, how can this be resolved?
7Help Needed: 2011 Nissan Sunny Low-End to High-End Instrument Panel Upgrade Issue At first: As shown in the picture, I bought a 2012 luxury version of the Sunny instrument panel. I removed the wires from the low-end panel and connected them according to the high-end socket order. Because I enlarged the wire holes when removing them, it led to poor contact. Initially, everything was normal except the fuel gauge didn't display. Could it be due to poor contact? Then, I reconnected the original low-end instrument panel, which led to the time, trip mileage, and fuel consumption resetting every time I started the car. Finally, I got another high-end socket. This time, I arranged the wire order for the high-end socket first, then connected wires from the low-end socket to the high-end socket (this method avoids enlarging the socket and causing poor contact). Now I'm stuck with the following issues: 1. The engine light is on. 2. The turn signal, headlight, and fog light indicators on the instrument panel don't light up, and there's no ticking sound when using the turn signal. 3. Each time I start the car, the time, average fuel consumption, and trip mileage reset. 4. After turning off the car, the tachometer stays at 1, then drops to 0 and returns to 1 when the car is started again, which seems normal. Everything else seems normal. Could fellow forum members help analyze what the problem might be? I'm almost crying.
8Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
9Hey folks, the left turn signal on my 2020 180V Automatic UP isn't working, and the dashboard blinks really fast. What should I do?
10How to set up 360-degree imaging to display when turning left or right?
