1.5T manual transmission, 2016 model, 50,000 kilometers. Spark plugs were replaced at 42,000 kilometers. Today, the car suddenly stalled, and after restarting, it stalled again after driving for a while. Can any experts help figure out what the problem might be?
Hey guys, at how many kilometers did you change your spark plugs? 😎
Has anyone experienced gear shift jerking after just replacing the spark plugs and cleaning the throttle? It was fine for two or three days, but then the jerking returned.
4The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
5I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
6The original spark plug failed after just over 10,000 kilometers. How about you guys?
7How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
8Car enthusiasts: My Yuxiang has now run 50,000 kilometers. Do I need to replace the spark plugs? If anyone knows, please share. Thanks!
9While driving, the central control screen suddenly went black, then restarted after two to three minutes, followed by a "pop" sound. Any ideas?
10Yesterday, I went for maintenance and replaced the spark plug assembly. I want to ask, after a year and having driven 20,000 kilometers, is it necessary to replace it?
