عبد العزيز عدي
عبد العزيز عدي
Sep 27
The dashboard always switches to miles automatically. Sometimes the wiper gets stuck when pressed once, then resets after pressing again, and only wipes once after another press. When enabling the lock car beep, the keyless entry is overly sensitive, resulting in a series of beeps. 😔 Does anyone else have the same issues?
عبد العزيز شهيد
عبد العزيز شهيد2023-10-19 00:21
The odometer often turns negative, and sometimes it unexpectedly hits over 100, while it's actually close to 150 or 160. [I want to be alone]
سعود شفيع
سعود شفيع2023-10-04 01:20
The wiper got stuck once.
محمد حسن
محمد حسن2023-10-03 13:28
The unit change on the instrument panel has occurred twice.
فهد همام
فهد همام2023-10-01 09:33
I've encountered this dashboard issue several times.
حسن ق
حسن ق2023-09-27 01:38
Adjust the instrument settings again. The wipers don't have this problem. Just turn off the sound if you want some peace. [I need some quiet] [I need some quiet]
Guys, I've got a problem! Sometimes when I go through the underground parking lot, I hear a "beep beep beep" sound. I check it out and find it's my car making the noise, and the yellow light flashes rapidly. The sound stops after about 10 seconds, but the yellow light keeps flashing for several minutes. It's happened more than once! Can anyone tell me what's going on? Can I turn it off? It's pretty annoying for others too.
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
How to download WeChat on the x90Pro: 1. Open the app store on your x90Pro device. This could be the Google Play Store for Android devices. 2. In the search bar, type "WeChat" and press enter. 3. Find the WeChat app in the search results and click on it. 4. Tap the "Install" button to download and install the app on your device. 5. Once the installation is complete, open the app and follow the on-screen instructions to set up your account or log in.
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
2022 HONGQI HS7 QiChang with five seats, driven 8000 miles. After rain, the keyless entry system failed. The key can only lock and unlock the doors; inside the car, the key is not recognized (both keys have this issue), and the car won't start (even emergency start doesn't work). HONGQI Smart Connection can start the vehicle, but it can't be driven away. The 4S shop inspection indicated a key matching fault, and after re-matching, it worked fine. However, the issue reoccurred 5 days later. What could be the problem? Have any fellow car enthusiasts experienced this? How do you deal with it?
My car has keyless entry, but after unlocking, the car gives four alarm sounds. What's going on? This didn't happen before. It used to just unlock automatically when I got close, with the lights flashing but no sound. Now it flashes four times and gives four alarm sounds!
Maserati Grecale
Maserati GrecaleEGP 3,850,000 ~ 4,350,000Gasoline & Petrol
