سعود صدام
2024-12-04 11:29
Why doesn't my luxury version have the low-speed active braking feature? I've tried several times, and the radar keeps beeping but it just doesn't stop.
علي جلال الدين
علي جلال الدين2024-12-05 10:35
Braking will only be triggered if your foot is not on the brake pedal and the radar detects a nearby obstacle.
Guys, I've got a problem! Sometimes when I go through the underground parking lot, I hear a "beep beep beep" sound. I check it out and find it's my car making the noise, and the yellow light flashes rapidly. The sound stops after about 10 seconds, but the yellow light keeps flashing for several minutes. It's happened more than once! Can anyone tell me what's going on? Can I turn it off? It's pretty annoying for others too.
I tried several methods to enable the one-touch window up/down feature on the 2017 320T, but none of them worked. Any advice?
How do I activate the auto door lock feature on the 2019 GAC GA6 Luxury Edition?
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
Does the 2021 Fengxing T5 EVO have an auto start-stop feature? It seems like it doesn't, but I'm not sure. I need to change the battery, but I'm not sure if it has the auto start-stop function.
Do you also feel that the keyless locking feature on the 2019 BMW 330 luxury facelift model is not very responsive or sometimes doesn't work at all?
The original halogen headlights on the Sharan were replaced with LED headlights, and they flicker during start-stop. Should I use 5054 to activate the xenon mode for the low beam to stop the flickering?
Where can I activate the active braking on the Cetus 1.5L naturally aspirated, luxury version?
How effective is the Seltos's active braking feature?
How to set up the lock beep for the 2019 MG ZS Global Luxury Edition? The central control is already set to lights and beep, but when locking, only the hazard lights flash without the beep. Tried all the suggestions from Douyin and Baidu, but still can't get the lock beep to work.
Toyota Toyota Granvia
Toyota GranviaAED 177,000 ~ 211,900Gasoline & Petrol
