If a four-wheel-drive vehicle uses dual motor drive, what is the purpose of the transmission? And is there still a drive shaft?
No 8AT, no four-wheel drive, I'm so disappointed... Even a four-wheel drive option would be fine. Why not bring in a high-power four-wheel drive? What's the point of introducing this version!
Is the Multivan's four-wheel drive not as good as the two-wheel drive? Does four-wheel drive consume more fuel? Should I buy the four-wheel drive or the two-wheel drive?
Is the four-wheel drive only available on the flagship version? Is the four-wheel drive system from BorgWarner?
4Does it have four-wheel drive?
5Are there 19 four-wheel drive models for sale?
6Can I switch between four-wheel drive and two-wheel drive while driving?
7Are cars still using dual-clutch transmissions (DCT) at over 50? Why not switch to an automatic transmission (AT)?
8What causes the steering wheel to make a noise when turning the shaft?
9Should I choose four-wheel drive or rear-wheel drive for this car, guys?
10Is this car rear-wheel drive or four-wheel drive?
