I've driven 300 kilometers, and the fuel gauge on the GWM Grenadier hasn't moved at all. Does it drop bar by bar, or does it decrease gradually as you use it? Does anyone know?
Hey everyone, I've got an issue with my new Beidouxing. When I slow down, it just stops moving even though the engine is still running. The gear lever feels loose, and I can't accelerate. The power windows should go down gradually, but instead, they drop all the way down uncontrollably. The mechanic couldn't figure it out either. Could anyone help analyze what's wrong? Thanks!
Hasn't the price for the Gladiator dropped? Why hasn't it decreased here yet?
Taycan owners, I have a question about a feature. As you might know, in the Taycan's triple display, the middle one shows the speed by default, and when the power meter is checked, it shows acceleration and energy recovery levels—blue for acceleration and green for recovery. In my car, with the default set to normal mode, when I press the accelerator, the blue bar shows up normally. However, when I press the brake, the green bar doesn't show at all, although the car brakes fine. Does this mean my braking relies solely on mechanical brakes without energy recovery? Is there a way to set it so the green bar shows normally when braking? I'm sincerely asking for advice, thanks everyone!
4In six months, I've driven 7,000 kilometers and have been using fast charging outside all the time. The mileage and display match up normally. Recently, I noticed the power drop is significant—three times the usual rate. The 4S shop checked and found no issues, suggesting that it might be due to fast charging causing a false charge. They recommended using the original slow charger. Initially, using the original slow charger seemed fine, but recently, the power drop is double what the display indicates. After charging, sometimes it's good, sometimes it's not. What could be the problem?
5Does anyone know why the water temperature gauge on the 2020 Jetour X70 with 1.5T engine sometimes shows six bars and sometimes five bars? I've already replaced the thermostat, but it still doesn't work.
6Does anyone know why the RPM gauge drops to 500 RPM when braking in a Ford Territory?
7My car is a 2019 model, and I've driven many cars, but none of them make the hissing sound over speed bumps like mine does. I haven't driven other Kodiaqs. Is it an issue with my car, or do all Kodiaqs have this kind of suspension noise?
8Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
9When the car is moving, there's a beeping sound. The seatbelt, fuel, and camera are all fine, and it's not the collision warning. Does anyone know what could be the reason?
10The car hasn't been driven for just two days, and the door can't be unlocked. I used the mechanical key to open the door, but there's no power at all inside. What's going on?
