فهد كمال
2024-11-26 09:54
How many car owners initially wanted to buy the top configuration of the Sienna (with AWD and brown interior) but ended up purchasing the Grevia AWD Prestige instead?
سعود توفيق
سعود توفيق2024-12-02 15:30
I am absolutely [I want to be quiet].
خالد جل
خالد جل2024-12-01 15:22
I didn't want captain chairs but still wanted the top configuration, so I directly got the 2023 top configuration of the GWM Grenadier in April. At that time, there were basically no top configuration Sienna models available locally.
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
I want to get a new car for my wife. She's currently driving an IS. After looking at a lot of cars, only the G70 shooting brake seems relatively pleasing. Here are my main concerns: 1. A friend mentioned that there's not much difference between the two cars, and the IS might be slightly better, so it may not be significant. 2. Recently, many car companies are offering discounts and promotions, but the manufacturer currently shows no sign of doing so. 3. Both cars require ordering and production scheduling, which means a long waiting time, making it awkward. 4. Since it's all about ordering and production scheduling, the options and configurations are not flexible enough. 5. I'm worried about their sales and the potential of dealership closures. Have any other car owners faced similar awkward issues? [Facepalm]
Hi everyone, when waxing my car, should I use solid wax or liquid wax? It's been a year, and I want to maintain the paint. I used liquid wax because the guy at the car wash said that due to the many angles and folds on the car, solid wax might leave white residue. In the end, I used liquid wax, but the results weren’t great. 🤦‍♂️
I want to ask how many kilometers the 009 actually runs in a test if it claims 700 kilometers. I'm considering purchasing it recently.
If you're considering buying another car and your annual usage is around 5,000 kilometers, with a budget of 80,000 RMB, you have several options. Since you like the appearance and interior of the Peugeot 508, you might want to look for a good condition second-hand Peugeot 508 within your budget. Additionally, you could explore other compact or midsize sedans that are known for their style and comfort. Make sure to check the vehicle's service history and condition if you're opting for a used car to ensure a good purchase.
Toyota Toyota Granvia
Toyota GranviaAED 177,000 ~ 211,900Gasoline & Petrol
