عبد العزيز ربيع
2020-05-09 15:33
What type of engine oil do you use during major maintenance?
خالد بارزاني2020-05-09 15:56
The engine oil used during major maintenance is the same as that used in regular minor maintenance, both using fully synthetic oil. However, during major maintenance, other components that aren't usually replaced need to be changed, including all the vehicle's fluids and consumable parts.
فارس عبدالرحمن2020-05-09 15:55
This car is a model from Maserati and is considered a luxury vehicle. For maintenance, it is recommended to use fully synthetic oil, specifically 5W-30. Choosing the original manufacturer's oil is advisable.
What type of engine oil is typically used for the MG3?
For a 2009 Acura MDX with a 3.7-liter engine, what type of engine oil should be used for maintenance?
What type of oil should be used for a 1.5T engine?
4What type of engine oil is used for the 2019 model?
5What type of engine oil do you all use?
6What type of oil should be used for a Nissan Kicks during maintenance?
7What type of engine oil do you guys use for the 2022 2.5 model?
8For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
9What oil do you all use for maintenance?
10What type of engine oil should everyone use for maintenance?
