سعود نوح
سعود نوح
Jul 22
Once the vehicle lost power, the dashboard no longer displays the gear position and G-value (not sure if it's G-value, it's a circular arc). Now, the dashboard only shows the date. Does anyone know what's going on? Please help.
سلمان قربان
سلمان قربان2022-07-22 17:13
If the battery is too severely depleted, the car's computer may shut down and you'll need to reset the system.
In your 2019 GS5, if you want to turn off the colored circle touch assistance on the center console, similar to the assistive touch on an iPhone, you might need to check the vehicle's settings menu. Look for options related to touch or display settings, and there should be an option to disable this feature. If you're not sure, consulting the user manual or contacting your local dealership for guidance might be helpful.
Is your Jetour X90 Manual Enjoyment 6-seater not showing the oil light on the dashboard during the self-check before starting the engine? Does it remain off even after starting the vehicle? Are you guys experiencing the same issue?
I got a 2011 manual 1.4 Peugeot 207 for my wife to practice driving. The car just arrived, and I have a few questions for experienced owners. 1. Does this car not show fuel consumption on the display, do I have to calculate it myself? 2. The original parking sensors make a beeping sound, but is there a distance display? Where can I find it? I couldn't locate it. 3. When the vehicle is running and I turn the key to the ignition position, there's a clicking sound. What's the issue?
How to adjust the fuel consumption display on the dashboard? It recently changed to something else, showing 33km like that. How can I change it back?
To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
How do I turn off the lyrics display on the driver's dashboard and the head-up display? It's distracting, and I couldn't find the settings to turn it off. Can anyone help me out? Thanks!
How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
Hey guys, need some help! Has anyone experienced the car suddenly braking on its own? The dashboard shows braking, but there's nothing in front.
Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
Maserati Granturismo
Maserati GranturismoAED 509,000 ~ 899,000Gasoline & Petrol
