I want to ask, how much air pressure do you guys put in the front and rear tires?
Does this indicate that the front two tires have low pressure?
I want to ask, why is the front brake caliper of the Taycan positioned at the front? Isn't it said that for mid-to-high-end cars, the front wheel calipers are generally positioned at the rear? Please explain.
Hi fellow car enthusiasts, how do you reset the tire pressure? The front right wheel keeps showing an error.
4Hey guys, how much weight can a six-seater with single rear tires carry? Located in Yunnan, Guizhou, Sichuan.
5I want to ask what brands of tires you all use.
6What brand of tires do you guys use?
7How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
8Is it necessary to rotate the front and rear tires at 45,000 kilometers?
9Guys, can you buy a spare tire for the 2008 model and put it in yourself? Will it fit?! What size should you get?
10Is there a problem if the tire pressures are different? Front left 240, rear left 250, front right 240, and rear right 233. Is it okay to drive?
