Which vehicle models share the same clutch master cylinder as the 2008 Suzuki Grand Vitara manual transmission?
Hello, my Suzuki Grand Vitara makes a buzzing sound when I accelerate. What could be the issue?
I bought a new car in 2018, and I'm looking to change the transmission oil. Could you tell me which type to use for the Suzuki Grand Vitara 5-door model?
42007 Suzuki Grand Vitara V6 2.7L suddenly has increased fuel consumption, what could be the issue?
5What spark plug model should be used for a 2014 Suzuki Grand Vitara with a 2.4 engine?
6What do you think of the 2007 Suzuki Grand Vitara 1.6 manual?
7Where can I buy parts for the 2009 Suzuki Grand Vitara?
8Why is the clutch master cylinder of my Haval leaking oil after running less than 20,000 kilometers?
9Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
10For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
