Can I switch to N when I'm not using 4WD while driving?
Hi everyone, for the 2021 Toyota Land Cruiser Prado LTD, how do you switch between high-speed 4WD and low-speed 4WD? When driving in full-time 4WD, do I need to come to a complete stop to switch between high and low-speed 4WD? Thanks!!
Hey car enthusiasts, my 2017 4WD Smart Drive version stalls when I shift to Neutral (N) or Park (P). Has anyone else experienced this issue?
Has anyone switched from a Jimny to an FJ or vice versa? I've been driving a Jimny for a while and I'm curious how it would feel to drive an FJ.
4Hey car enthusiasts, when I put my 4WD on a lift, the front wheels spin but the rear ones don't. After a while, it shows a "4WD Overheat" warning. But when I drive on the road for a bit, the error code disappears.
5Can I switch between four-wheel drive and two-wheel drive while driving?
6Hey guys, I have a 2019 Kicks. When I'm waiting at a red light and switch to N gear, then back to D, the acceleration feels noticeably slower. Has anyone else experienced this?
7I heard that the fuel consumption of the 4WD petrol version is higher than the 2WD. How much higher is it? Can the 4WD version switch to economy mode to achieve full 2WD?
8Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
9I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
10I have a 2019 4WD model, and the fuel consumption is always around 11.6. Could it be related to those buttons like the low-speed 4WD? Did I press the wrong button while driving? Which button should I press for normal driving?
