What's the fuel consumption of the Grand Highlander? If it's similar to the plug-in hybrid models in China, then it might be better to go for the Grand Highlander and avoid the hassle of charging.
Comparing the 2004 Bluebird Sylphy 2.0 and the 2007 Passat 1.8T: 1. **Engine Performance**: - The Bluebird Sylphy 2.0 typically features a 2.0-liter engine, which might offer decent power and reliability for daily driving. - The Passat 1.8T comes with a turbocharged 1.8-liter engine, generally providing more horsepower and torque, which can result in better acceleration and performance. 2. **Fuel Economy**: - The Bluebird Sylphy might have slightly better fuel economy due to its naturally aspirated engine. - The Passat, with its turbocharged engine, could consume more fuel but may offer better performance. 3. **Driving Experience**: - The Bluebird Sylphy is often appreciated for its smooth and comfortable ride, suitable for everyday commuting. - The Passat, on the other hand, might provide a more engaging driving experience, especially with its turbocharged engine. 4. **Interior and Features**: - Both cars might offer similar interior comfort, but the Passat could have more advanced features, given it is a higher-end model. 5. **Reliability and Maintenance**: - The Bluebird Sylphy is generally known for its reliability and lower maintenance costs. - The Passat could require more frequent maintenance due to its turbocharged engine, but it is also known for its solid build quality. Overall, the choice depends on what you're prioritizing: fuel economy and reliability with the Bluebird Sylphy, or performance and features with the Passat.
4I want to get a new car for my wife. She's currently driving an IS. After looking at a lot of cars, only the G70 shooting brake seems relatively pleasing. Here are my main concerns: 1. A friend mentioned that there's not much difference between the two cars, and the IS might be slightly better, so it may not be significant. 2. Recently, many car companies are offering discounts and promotions, but the manufacturer currently shows no sign of doing so. 3. Both cars require ordering and production scheduling, which means a long waiting time, making it awkward. 4. Since it's all about ordering and production scheduling, the options and configurations are not flexible enough. 5. I'm worried about their sales and the potential of dealership closures. Have any other car owners faced similar awkward issues? [Facepalm]
5Help Needed: 2011 Nissan Sunny Low-End to High-End Instrument Panel Upgrade Issue At first: As shown in the picture, I bought a 2012 luxury version of the Sunny instrument panel. I removed the wires from the low-end panel and connected them according to the high-end socket order. Because I enlarged the wire holes when removing them, it led to poor contact. Initially, everything was normal except the fuel gauge didn't display. Could it be due to poor contact? Then, I reconnected the original low-end instrument panel, which led to the time, trip mileage, and fuel consumption resetting every time I started the car. Finally, I got another high-end socket. This time, I arranged the wire order for the high-end socket first, then connected wires from the low-end socket to the high-end socket (this method avoids enlarging the socket and causing poor contact). Now I'm stuck with the following issues: 1. The engine light is on. 2. The turn signal, headlight, and fog light indicators on the instrument panel don't light up, and there's no ticking sound when using the turn signal. 3. Each time I start the car, the time, average fuel consumption, and trip mileage reset. 4. After turning off the car, the tachometer stays at 1, then drops to 0 and returns to 1 when the car is started again, which seems normal. Everything else seems normal. Could fellow forum members help analyze what the problem might be? I'm almost crying.
6Does the 2024 Highlander's particulate filter still get clogged? Fellow car enthusiasts, is your particulate filter still getting clogged? I've heard that the materials used now are better, so the chances of clogging are lower. I'm considering just replacing it with an empty shell to avoid future headaches.
7Hi fellow car enthusiasts, I have a 1.6 CVT that's been running for ten years with over 60,000 kilometers. Last month, I just did maintenance, changed the transmission fluid and spark plugs. It was running fine for the first few days, but recently it's been jerking occasionally when I lightly press the accelerator. It's similar to a manual car when you give gas without fully releasing the clutch. The engine goes "woo-woo-woo," and the whole car shakes a bit, but the speed doesn’t increase. Then, when I press the accelerator harder, it goes back to normal. Does anyone know what might be happening?
