نايف نادر
2024-08-24 19:56
When the vehicle just starts, there's a whistling sound from the front wheels, but it disappears after driving for a while. What's the reason? Could it be that a small stone got into the brake disc?
فهد شهيد
فهد شهيد2024-09-15 16:27
It should be, me too.
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
Has anyone experienced a whistling noise while driving the all-electric Lavida? Not sure what the reason is. Could it be the brake pads? But it makes the sound even when I'm not braking. It comes and goes.
Regarding the strange noises in my Changan CS75, the first issue is a buzzing sound from the central control screen. The second issue is a rubbing noise when the seat moves back and forth. The third issue is a noise like stones hitting when the vehicle is driving or waiting at a red light. What do you guys think? I just got it 2 months ago. 😊
I just got a 2013 model with a 1.4t engine, and it's been driven for 130,000 kilometers. When I use lower-grade fuel, the high-pressure fuel pump makes a buzzing sound. What could be the reason for this, experts? The sound goes away after driving for a while, but it happens right after starting the car.
I've got a 2018 GWM GS7, and recently the engine's been making a "da-da-da" sound while driving. What's going on?
When the 2018 F150 XLT makes a rattling noise when you release the accelerator while it's cold, but the sound disappears when the vehicle warms up, it could be due to several reasons. Since you've already replaced the timing components and the turbo, you might want to check other areas such as the exhaust system, heat shields, or engine mounts for any loose parts or issues. It's also advisable to consult a mechanic to diagnose the problem accurately.
Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
