نايف أزهر
2024-01-20 15:16
When the suspension is raised to its highest level, after parking and turning off the engine, the vehicle sometimes lowers to a normal height. I haven't activated the easy entry/exit feature, and it doesn't lower immediately after turning off the engine. Sometimes it doesn't lower at all, while other times it lowers on its own.
Comments( 6 )
فهد شخبوط
فهد شخبوط2024-05-05 21:38
Pay attention to the 4WD mode. When you adjust the mode, the suspension height will change. If you raise the suspension in auto mode and restart the car, the height shouldn't change. If that's the case, then there's no issue.
خالد أصغر
خالد أصغر2024-04-05 17:53
During maintenance, check the wear level of the rear airbags and replace them if necessary. As for whether it will decline, as long as it's not excessive, just leave it alone.
عبدالله ليث
عبدالله ليث2024-01-23 16:22
Don't rule out the possibility of a leak.
عبدالله رامي
عبدالله رامي2024-01-22 08:10
When I activate the entry/exit mode, it automatically rises as soon as I shift into D after starting. However, if I let it warm up a bit before driving, it might not rise immediately and may take a few kilometers before it lifts.
سلمان عين
سلمان عين2024-01-21 09:32
The air suspension automatically adjusts according to the road level, so normally there's no need to worry.
حسين ماجد
حسين ماجد2024-01-21 09:29
Convenient entry and exit are not very useful.
The car is difficult to start two hours after turning off the engine.
Is your CarPlay music playback smooth? How do you fix any issues? Also, the automatic lock/unlock feature sometimes doesn't work properly, which is frustrating. Additionally, after turning off the engine, the power cuts off immediately, so I can't close the windows if I forget. Lastly, when starting the car, I have to manually turn on the central control. Is this a settings issue on my part? How do you all deal with these issues? Or am I the only one experiencing them?
Hey guys, why does the AC sometimes turn on by itself after starting the car? I usually don't forget to turn it off.
Will the driving lights turn off automatically after locking the car if they are not switched off?
Even with power in the battery, my Jinxuan manual sometimes doesn't respond when starting. After turning it on and off a few times, it starts. Does anyone know what might be causing this?
Do you have any tips for fixing a car door handle that sometimes doesn't return to its original position after being pulled?
Can the little golden figure on the dashboard be turned off so it doesn't rise up?
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
