سعود دين
2023-12-23 09:23
What could be the issue if the auto start-stop feature on a 3.0 Grand Cherokee hasn't worked since I bought it less than a year ago?
Comments( 9 )
صلاح الدين فهد
صلاح الدين فهد2024-01-31 17:10
If it doesn't start, then it doesn't start. I just never bothered with it. It's fine if it doesn't start.
حسين أمير
حسين أمير2024-01-18 22:21
It seems like the car's air conditioning doesn't stop and start, right?
عبد العزيز مرشد
عبد العزيز مرشد2024-01-16 09:44
Is your vent temperature set to "Low"? The system will always display "Heating or cooling the cabin." Close the vent or raise the vent temperature to make it normal.
سعود شعبان
سعود شعبان2024-01-15 20:05
Your vehicle's condition does not meet the requirements for auto start-stop to function.
أحمد عوادة
أحمد عوادة2024-01-05 22:48
Under the front passenger seat, next to the main battery, there's a small starter battery. You can replace it with a universal one similar to the small starter battery in a Mercedes, as long as the capacity is the same. It costs over 300 RMB. I've already replaced mine.
سعود دين
سعود دين2023-12-24 21:59
It's not like I drive less; even on long trips of one to two thousand kilometers, it has never worked!
سلمان وسيم
سلمان وسيم2023-12-24 20:46
Low mileage, battery discharging.
حسين ماجد
حسين ماجد2023-12-23 14:26
The car battery is dead.
علي عبد الناصر
علي عبد الناصر2023-12-23 10:58
New car? Is the auto start-stop warning light on? This feature can't be turned off permanently; you have to manually disable it every time you start the car.
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
