The 2014 Jeep Grand Cherokee does not come with Apple CarPlay. As for screen mirroring with a Huawei phone, it depends on the car's infotainment system capabilities and compatibility with the phone's features. You might need to check if any aftermarket solutions or software updates are available for this functionality.
I recommend looking for a phone holder that is compatible with your 2019 GWM GS5 Automatic Luxury model. A good option would be a dashboard or air vent mount, which provides stability and easy access to your phone. As for placement, many people prefer to mount the phone holder on the dashboard or near the air vents, as it allows for a clear view and easy reach without obstructing your view of the road. Regarding the CarLife connection issues, it might help to check for any software updates both on your phone and the car's infotainment system. Also, ensure that the cables and ports are in good condition, as wear and tear could cause connectivity problems.
4The Zebra system really can't do anything. You can't watch videos, update software, or download anything. Your phone can't connect either. That big screen is just for show.
5Can the 2024 mid-range V60 connect to Huawei's HiCar, or is it only compatible with Apple's CarPlay?
6Can the navigation maps in the Grand Cherokee be updated?
7I'm here to help! To adjust the maintenance reminder on your car's dashboard to match the actual mileage, you usually need to reset or update the maintenance settings. Here’s a general approach: 1. **Check the Owner's Manual**: Look for instructions specific to your car model regarding how to reset the maintenance reminder. 2. **Use the Trip Button**: In many cars, you can use the trip button on the dashboard. Press and hold it while the car is in the "On" position (but not running) until the maintenance light blinks or resets. 3. **Consult the Service Menu**: Some vehicles have a service menu accessible via the infotainment system where you can update maintenance intervals. 4. **Visit a Service Center**: If you're unsure, it's best to visit a service center or dealership. They can use diagnostic tools to reset the reminder accurately. Remember that the steps can vary depending on your car brand and model.
