فهد مجيد
2024-04-08 12:41
My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
عبد العزيز سلمان
عبد العزيز سلمان2024-04-08 13:00
Three months after I got my car, it also showed a turn signal malfunction, but the turn signals were working normally. I went through the warranty process, got a new headlight assembly, and it fixed the issue.
I want to ask if anyone else has experienced this with the 720S: sometimes when I start it, a fault message pops up, but after driving for a while, it disappears on its own. When I check, it says there's no issue. Has anyone else encountered a similar situation? [Shocked]
The check engine light is on, indicating an engine emission fault, but the DPF regeneration indicator is not lit. Holding the regeneration button doesn't work, and sometimes the vehicle doesn't accelerate properly. What could be the reason for this? Any ideas, everyone?
The 2014 Zhiya's Blind Spot Detection (BIUS) system showed a fault warning in July this year, but today the fault disappeared and the feature is working again. What could be the reason?
I was driving a Haima S5 1.6 CAT Creative Edition on the highway for about 6 hours, and suddenly the car couldn't accelerate. After stopping and turning off the engine for a while, it could accelerate again. What could be the problem? This has happened twice already, once on the highway before and once this year. When it couldn't accelerate, the car showed a fault code, but after parking overnight, the fault code disappeared. Has anyone else experienced this?
I have a 2017 V60, and sometimes I hear a clicking noise from the chassis when driving at high speeds. The noise disappears if I lightly tap the brakes. I suspect it might be an issue with the brake system, but I've been to the dealership twice and they couldn't solve it. Has anyone experienced a similar problem? Any solutions would be greatly appreciated!
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
