عبد العزيز نور
2024-01-21 23:01
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
سلمان سليمان
سلمان سليمان2024-02-08 22:35
The temperature sensor is broken. It's not too expensive, around 100 or so.
خالد وهاب
خالد وهاب2024-02-04 20:24
A couple of days ago, mine broke too. You can replace the small part separately; it's not expensive. I forgot the exact name.
أسامة سلمان
أسامة سلمان2024-01-29 16:51
The ignition coil is broken, probably because the claw snapped.
خالد جابر
خالد جابر2024-01-22 04:53
The driver's side heating servo motor is broken.
The engine temperature is normal, but the air from the heater is not warm.
The rear air conditioning vents are not blowing cold air?
I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
What's going on when the heater in a Changan Yuexiang is blowing cold air?
Is anyone else experiencing an issue with the footwell air vent on the Aion? Even after turning off the footwell vent on the control panel, cold air still blows on my ankles. It's really uncomfortable on a long drive. Anyone else having this problem?
Is the warm air blowing on the windshield of your LC120 also weak?
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
