I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
For the 2014 Jeep Grand Cherokee with a 3.6 engine, the manual recommends using 0W-20 oil. However, the repair shop suggests using a higher viscosity oil.
Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
Hey guys, I'm thinking of buying a 2014 Grand Cherokee. Can anyone tell me what the current market situation is like?
4Hi everyone, I have a 2016 3.6 Grand Cherokee. Recently, after switching to 0-20 oil, I've noticed a "doo-doo" sound coming from the exhaust area inside the car. It's not very noticeable when I get out of the car, seems like some kind of resonance. Also, after the oil change, the engine sounds louder. I've driven 400 km since then and there's no improvement. Any ideas?
5Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
6Hey fellow Grand Cherokee owners, when I start my car in the morning, I hear a "clattering" sound from under the chassis, but it goes away after starting. What could be the reason for this?
7I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
