Hi everyone, I'm looking for advice from fellow Grand Cherokee owners. A braking distance of 43 meters seems pretty bad. Has anyone done any modifications? What brands did you use? Is it enough to just replace the brake discs, calipers, and pads? What's the braking distance after modification? Also, has anyone switched to LED headlights? How's the performance? Which brand did you go with?
Should I replace the brake pads with better ones or go for the original ones? What brands do you guys usually choose?
Which brand of brake pads is good for replacement?
What brand are the original brake pads, or can anyone recommend a good type of brake pads? Thanks!
4Hey guys, quick question. Has anyone with the 2021 Diamond Edition upgraded to LED lights? Did you change the lenses too? Also, for those who do maintenance outside the dealership, what brand of engine oil are you using?
5Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
6Hi everyone, I'm looking for advice from fellow Grand Cherokee owners. A braking distance of 43 meters seems pretty bad. Has anyone done any modifications? What brands did you use? Is it enough to just replace the brake discs, calipers, and pads? What's the braking distance after modification? Also, has anyone switched to LED headlights? How's the performance? Which brand did you go with?
7Hey guys, any recommendations for brake discs and pads for the 2019 model? 😊
8I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
9Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
10Consulting everyone, if I change my manual 30 to high-end 18-inch wheels, do I need to modify the brake discs and calipers?
