Hey fellow Grand Cherokee owners, the air suspension can rise normally in the first mode, but the second mode just keeps flashing. What's going on?
Comments( 6 )
How do you switch between the advanced mode and normal mode of the Phaeton's air suspension? In the advanced mode, is the front lower and the rear higher when parked? [Facepalm]
Is it normal for the accelerator pedal to make noise? I've had this issue since I first got the car, and it's really annoying. The dealership says it's normal. Fellow car enthusiasts, is this really normal?
What should I pay attention to when installing electric running boards on the Elite version with air suspension? Do I need to select the jack mode?
4Does anyone know why the suspension rises to the highest level when parked and then drops back to normal after a while?
5I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
6What mode should I use for my Jeep Grand Cherokee in snowy and icy weather?
7Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
8Why does the air conditioning keep turning on and off at idle in first gear?
9Hey fellow Grand Cherokee owners, when I start my car in the morning, I hear a "clattering" sound from under the chassis, but it goes away after starting. What could be the reason for this?
10I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
