Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
Hi fellow car enthusiasts, how do you reset the tire pressure? The front right wheel keeps showing an error.
For a 2015 diesel Grand Cherokee, besides the original engine oil, what other options are suitable... Also, recently when I floor the accelerator around 2000 RPM, there's a whistling sound. Have any fellow car enthusiasts experienced this?
Does anyone know where to replace the cigarette lighter fuse with a key symbol under the center console of the 2016 Grand Cherokee mechanical gear model?
4Hey folks, I have a 2012 Grand Cherokee 5.7. Recently, the sound for the steering alert, seatbelt alert, and radar alert has disappeared. I guess it's probably an issue with the buzzer. But where is this buzzer located?
5How did you deal with the issue of the water temperature sensor malfunctioning and the temperature light constantly flashing? I replaced the temperature sensor, but it started flashing again after two months. Did you replace the thermostat assembly? 2017 model.
6Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
7Hey car enthusiasts, has anyone switched to AT tires on their Grand Cherokee? How's the experience?
8Do any of you fellow car enthusiasts feel that the 1st and 2nd gears are noticeably jerky?
9I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
10Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
