خلف حسين
2024-02-28 00:41
Hey family, my Grand Cherokee suddenly started leaking water from the sunglasses holder today. Anyone else had the same issue?
Comments( 6 )
سلمان نوري
سلمان نوري2024-10-05 11:14
The sunroof is blocked and leaking. My car is flooded...
فهد معتمد
فهد معتمد2024-02-29 12:23
Where is the sunroof drain hole located on the Grand Cherokee?
ميسور حسن
ميسور حسن2024-02-28 11:34
Sunroof drainage holes are blocked.
حسين ماجد
حسين ماجد2024-02-28 08:22
The sunroof is leaking.
علي بلال
علي بلال2024-02-28 07:53
There are also sunroof drainage holes!
علي بلال
علي بلال2024-02-28 07:50
No! I personally suggest you check the sunroof seal!
What could be the issue if the auto start-stop feature on a 3.0 Grand Cherokee hasn't worked since I bought it less than a year ago?
What could be causing the very strong jerkiness in the 3.0 Grand Cherokee's start-stop system?
I've had my Grand Cherokee for 5 years now, and it's done 60,000 kilometers. I'm starting to hear a strange noise when braking. Can anyone offer some advice? Thanks 🙏
Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
Today when I was reversing, the reverse camera suddenly showed nothing, and the screen started flickering. What's the problem here? Can anyone help me fix this?
When driving, sometimes when I press the accelerator, I feel a jerk, like there's suddenly no power, and then it's fine again. What's going on? Does anyone else have the same issue?
Hey fellow Grand Cherokee owners, when I start my car in the morning, I hear a "clattering" sound from under the chassis, but it goes away after starting. What could be the reason for this?
I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
