نايف أمير
2024-03-02 23:24
فهد شهيد
فهد شهيد2024-03-03 00:17
Did you accidentally shift into Neutral while driving?
نايف أمير
نايف أمير2024-03-02 23:24
The vehicle is a 2016 model with a 3.0L engine.
The gear shift light for the 150 isn't working. Could it be that a button hasn't been turned on? The P, R, D indicators don't light up at night when the car is running.
How to open and close the electric door of a Vellfire without shifting to P gear?
MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
Are there any T-Cross owners here? Is your car shifting smoothly? I feel like my gear shifts are quite slow.
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
When the MINI is in D gear and you brake, if there's a prompt to shift the transmission to P gear, there might be a couple of reasons for this. It could be an issue with the gearbox or a safety feature that's activating. If the car doesn't move when you release the brake, it might be due to a malfunction or an electronic system engaging to prevent movement. It's best to consult the vehicle's manual or contact a professional mechanic to diagnose the issue accurately.
Nissan X-Trail e-Power, I have two questions: 1) When the door is opened in D or R gear, the car alarms, but it doesn't shift back to P gear. Is that correct? I seem to remember it would automatically shift back to P gear before. 2) The speed-sensitive setting for the front wipers is on, but it doesn't seem to activate automatically when it rains. Why? Thanks for the explanation.
When you shift to D gear and press the accelerator to start, does your car make a buzzing sound, like exhaust resonance?
Why is there an impact when shifting from R to D gear?
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
