نايف أزهر
2024-01-20 15:13
Does anyone know why the suspension rises to the highest level when parked and then drops back to normal after a while?
عبدالله رامي
عبدالله رامي2024-01-22 08:17
If it stays upright overnight at a normal height, then there's no problem. If it's deflated, then there's a leak.
عبدالله رامي
عبدالله رامي2024-01-22 08:11
Yes, it's all like this.
Does anyone know why the Yashenti dashboard needles suddenly drop to zero while driving and then return to normal after 1-2 seconds? Thanks, everyone.
Is anyone familiar with solving the issue of idle speed occasionally rising to 2000 RPM and then dropping back down on a stock MG HS? It's particularly noticeable at low speeds.
Has anyone experienced their car's tachometer suddenly jumping above 3000 RPM and then dropping back down while driving?
When the suspension is raised to its highest level, after parking and turning off the engine, the vehicle sometimes lowers to a normal height. I haven't activated the easy entry/exit feature, and it doesn't lower immediately after turning off the engine. Sometimes it doesn't lower at all, while other times it lowers on its own.
Hey everyone, does anyone know why a car would suddenly brake uncontrollably for a moment while driving normally, and then go back to normal? Any ideas?
Why does the Taycan revert to normal mode after changing the driving mode settings and getting back in the car?
The air conditioning was set to level 4, but there was still barely any cold air and the airflow was very weak. What's going on? After a day, it went back to normal. It's really frustrating.
Why does the chassis automatically return to level 1 after being raised to level 2 for a while?
Jeep Jeep Grand Cherokee
Jeep Grand CherokeeAED 129,900 ~ 375,000Gasoline & Petrol
