سعود فيصل
2022-07-27 23:50
Does the Gladiator have a differential lock? How many does it have?
نايف أمينة
نايف أمينة2022-08-20 11:03
There's no standard version available, but there is a parallel import. It's 15 more expensive.
عبد العزيز شعبان
عبد العزيز شعبان2022-08-05 23:12
It's available in the Canadian version, but it's a bit more expensive.
علي محمد
علي محمد2022-08-02 18:25
No, you can change to the CJ differential lock. There is a special version available that doesn't require changing the half-shaft. Installing the original one requires cutting or replacing the half-shaft, which is a bit more troublesome and not as strong as the modified version.
