avatar-image
جعفر عمر
May 16
Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
نايف عوض
نايف عوض2024-05-17 01:17
Push the wiper on the left inward (to the right) to spray water.
The washer fluid on my Rapid is spraying too coarse and too low, hitting below the wiper blades. How can I adjust it to spray finer and higher?
The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
What could be the reason for the windshield wipers not spraying water? Can someone with experience explain this?
How long can windshield wiper blades last?
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
Peugeot 3008 windscreen washer not working? I've already added three bottles of fluid.
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
Maserati Maserati Ghibli
Maserati GhibliAED 399,000 ~ 599,000Gasoline
