عبد العزيز ميسور
2023-12-16 03:51
Geely sometimes has no response when starting, but the dashboard and electrical components are powered. It happens occasionally. Is there a solution?
Has anyone experienced occasional power loss with a 2006 Volvo S40? Sometimes the car loses power even when just listening to music.
Hi everyone, sometimes my Mazda 2 sedan has a hard time starting, but it only happens occasionally. It struggles on the first attempt, but starts up easily on the second try. What could be the issue here?
The third-generation Haval H6 MAX occasionally has a noticeable jerk or thump when starting at a red light. Does anyone have any solutions to fix this?
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
When the car's steering angle exceeds 100 degrees, the chassis sometimes makes a "ka-ka" sound. What's the issue? It happens occasionally.
Why does the car sometimes not respond when starting, even though the battery and dashboard lights are normal?
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
Maserati Maserati Ghibli
Maserati GhibliAED 399,000 ~ 599,000Gasoline
