فهد وي
2023-08-13 11:45
محمد فارس
محمد فارس2023-10-10 13:01
There are 6 inside, not cheap.
محمد فارس
Replace the air conditioning motor.
Hey folks, my emission warning light was on for a few days, then it went off. Anyone else had the same issue? What could be the reason?
A few days ago, while fixing the circuit, the technician caused my triple meter to stop displaying. Now it can display, but I don't know how to adjust it to work properly. Any fellow car enthusiasts know how to adjust a triple meter? Thanks.
Don't buy unpopular cars. I regret buying the Chery Kaiyi X3. There's basically no after-sales service, and they charge you if you're a few days late for maintenance.
My car keeps blowing the starter fuse, and I can't figure out why. I can't fix it. Does anyone else have the same issue?
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
Is the warm air blowing on the windshield of your LC120 also feeling weak? Is it the same for you guys?
Maserati Maserati Ghibli
Maserati GhibliAED 399,000 ~ 599,000Gasoline
