Why is the steering wheel of the Mitsubishi Galant particularly heavy even though there's power steering fluid?
There could be several reasons why your 2.9T6 steering feels particularly heavy. Common causes might include low power steering fluid, issues with the power steering pump, or alignment problems. It's also possible that the tires are underinflated or there's an issue with the steering linkage. It would be best to have a professional mechanic inspect your vehicle to diagnose the exact cause.
Why can the Bluetooth in the Mitsubishi Galant only make calls and not play music?
Why is the steering of the Haval H2 so heavy?
4Why does the Ford F150 feel particularly sluggish when I engage 4WD, turn the steering wheel all the way, and accelerate?
5Replacing the power steering fluid in a 2010 Acura might improve the heaviness of the steering wheel.
6Why is the dashboard still showing "add windshield washer fluid" even though I've filled it up and it's spraying normally? Any suggestions?
7What could be the issue if the steering suddenly becomes heavy and hard to turn, even though there's enough fluid?
8Is the steering wheel of the 1.5 manual base model heavy?
9Why is the steering wheel heavy? Is it supposed to be that heavy?
10Hello fellow car enthusiasts! Does anyone else feel that the steering wheel in the 2017 Jetta automatic is particularly heavy? Any solutions to this?
