سلمان سعد
2020-08-18 09:55
Mitsubishi Galant with automatic/manual transmission, when put in gear, the idle speed is low and it seems like it's about to stall. What could be the reason? Thanks, experts.
حسن إلياس
حسن إلياس2020-10-27 20:39
Throttle body cleaning and recalibration.
حسن سعد
حسن سعد2020-08-18 10:08
This might be caused by excessive carbon buildup in the engine. I think you could start by cleaning the engine's throttle body. If that doesn't help, you might consider replacing the spark plugs to see if it makes a difference.
Mitsubishi Galant D gear won't engage, does anyone know what's going on?
The message "Reduced Engine Performance" on your car usually indicates there's a problem that needs attention. This could be due to several reasons, such as issues with the fuel system, air intake, or engine sensors. The fact that the car stalls at low speeds suggests it might be a problem affecting the engine's idle function or fuel delivery. It would be best to have it diagnosed by a professional to pinpoint the exact cause.
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
Is anyone familiar with solving the issue of idle speed occasionally rising to 2000 RPM and then dropping back down on a stock MG HS? It's particularly noticeable at low speeds.
What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
Why is it making a rattling noise when I put it in reverse gear recently? Can any experts give some advice?
In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦‍♂️
