Long press the lock button, the yellow light turns on, causing all the window control buttons to malfunction. What should be done?
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
4Why do you have to press the rear window button once before starting the 2013 GS5?
5My sunroof won't open, what's going on? I press the button, but there's no response at all.
6Are there any owners of 2019 two-wheel drive or four-wheel drive luxury models here? I have a question. For models where only the driver's window has the one-touch up/down feature, can you long-press the lock button on the key to raise the windows? Can this be upgraded at the dealership? My 2019 four-wheel drive luxury model can only close the sunroof with the key, not the windows.
7After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
8The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
9Fellow car enthusiasts, does your 2018 manual comfort model have the feature to lower the windows by long-pressing the unlock button on the key?
10Does the 2013 Roewe have automatic window closing when locking the car, or can the windows only be closed by holding the lock button?
