عمر سليمان
2020-12-18 05:17
If you are experiencing an issue with your Mitsubishi Galant where holding the lock button causes the yellow light to come on and the window control buttons become unresponsive, here are a few steps you can try: 1. **Reset the System**: Sometimes, simply turning off the car and restarting it can reset the electronic systems, including the window controls. 2. **Check the Fuses**: Locate the fuse box and check if any of the fuses related to the power windows or central locking system are blown. Replace any blown fuses with the correct type and rating. 3. **Inspect the Battery**: Ensure that your car battery is not low on charge, as insufficient power can cause electronic systems to malfunction. 4. **Consult the Manual**: Refer to your vehicle's owner manual for any specific troubleshooting steps related to the power windows and central locking system. 5. **Visit a Technician**: If none of the above steps work, it might be best to consult a professional mechanic or visit a Mitsubishi service center to diagnose and fix the issue. Please do not attempt to fix any electrical issues if you're not familiar with car electronics, as it might lead to further damage.
11-year manual transmission, car powers on but won't start. Any experts here to help? 😊 Checked the fuse box too. 😢
Hello everyone, I've installed the folding mirrors and the 360 system on my 300h. When I touch the door to lock it, the mirrors fold in, but the windows don't roll up. What could be the reason? Also, there's a rapid noise coming from the driver's door when it's really hot. Any ideas?
My 2013 model's driver side door lock isn't locking. Is it a problem with the lock itself or the electronic control? Any fellow car enthusiasts facing the same issue? How did you resolve it?
To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
It would be great if the MG One could automatically close the car windows when locking the vehicle. I hope the manufacturer can upgrade the system.
Why isn't the left side of the lights on my Kia Cerato working when I lock the car? Is it a blown fuse or a burnt-out bulb?
Is the left front and rear lock lights of the Kia Cerato not working because the bulb is broken, or is it a blown fuse? Does anyone know?
The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
Skoda Octavia Pro's large screen keeps rebooting automatically even when the car is locked and powered off. Is there any way to fix this?
