How to handle a Mitsubishi Galant OBD connection issue?
What could be the issue if the water jug and battery lights come on when the ignition is turned on in a Mitsubishi Galant?
Why is the steering wheel of the Mitsubishi Galant particularly heavy even though there's power steering fluid?
Mitsubishi Galant D gear won't engage, does anyone know what's going on?
4Why can the Bluetooth in the Mitsubishi Galant only make calls and not play music?
5Does the 2009 Mitsubishi Galant have built-in Bluetooth or an AUX port? Looking for answers.
6Is buying a 2011 Mitsubishi Galant, first-hand from a private seller, for 40,000 a good deal or overpriced?
7Is it still easy to find maintenance and repair parts for the 2007 Mitsubishi Galant? It's probably hard to find them now, right? Looking for a reply.
8Would you dare to use the OBD interface to connect electronic devices with a head-up display function?
9Is oil consumption a common issue for the Mitsubishi Eclipse Cross? How should it be repaired?
10How to connect Bluetooth in a 2010 Mitsubishi Lancer?
