Experts, my Mitsubishi Galant's remote lock doesn't flash the lights, but it can still lock. The repair shop checked the hood and trunk, and everything's fine. They said my central control module is broken, but they can't find the module in the car. Any guidance from the experts would be appreciated...
Mitsubishi Galant with automatic/manual transmission, when put in gear, the idle speed is low and it seems like it's about to stall. What could be the reason? Thanks, experts.
My car key no longer has the unlock function. Can any expert provide some guidance? It's a 2017 Roewe RX5.
I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
4I recently took my 2021 manual 1.6 35p to the dealership to replace the clutch pedal. After coming back, I noticed that when I lock the car, the indicator lights flash rapidly six or seven times. Previously, they would flash slowly twice. Additionally, there's a warning about low key battery, but the key can still control the car from a distance. What's going on?
5The engine malfunction light on my 2010 City recently started flashing. Diagnostic code 14 indicates irregular misfires. I've replaced the spark plugs, ignition coils, and cleaned the fuel injectors, but the issue still occurs intermittently. Every time the light flashes, I restart the engine and the issue disappears for a while before reappearing. Any knowledgeable experts or fellow car enthusiasts have any advice on how to handle this issue?
6I found a problem today, the taillights flashed by themselves. My friend and I were outside the car, the doors were locked, and we were less than two meters behind the car. The key was in my pocket, and the taillights flashed twice on their own, with about a thirty-second interval! What's going on!!! It's different from the hazard lights, it was a quick flash on and off. Is it haunted? 👿👿👿👿👿
7I need some guidance from the experts. I'm new to cars and currently, my family doesn't own one. My husband works nearby, but I commute 40 kilometers to the suburbs for work every day. We live in an old neighborhood without home charging facilities, and I'm thinking of buying a new energy vehicle. I've had my license for six years but haven't driven much. I liked the appearance of the Zeekr X but heard the rear space is small. Personally, I like Zeekr and Ora, and I'm also considering Deepal. I'm really confused and don't know which car to buy. Any advice from the experts would be appreciated.
8My 2021 Outlander's trunk suddenly won't open (can be opened with the emergency button inside). The lock button on the driver's side isn't working properly, can't lock the car. Any experts know how to fix this?
9Hey everyone, the screen on my Volvo suddenly went dark. Does anyone have any solutions? Any guidance would be appreciated. I don't want to take it to the shop, I want to figure it out myself.
10Car enthusiasts, on the 2021 Strength Edition, why does the trunk lock keep flashing even after the doors and trunk are closed? How can I solve this issue? Please let me know if you have any ideas. In my video, the flashing red dot is right at the trunk lock.
